complete rb25det
rb25 head with lifters and valves still untouched$450
rb25 block $450
power steering pump $50
A/C compressor $100
rocket covers both $50
camshafts intake and exhaust $100
intake manifold comes with injectors, anything that bolts onto it $150
exhaust manifold stock $50
cross over pipe with stock bov $50
flywheel still in good condition can give clutch as well for
free still in pretty good condition $100
timing covers and coil pack covers $80
throttle body $50
ecu $100
alternator $ 60
wiring loom $ 120
o2 sensor $ 30
engine mount brackets no rubber $30? for both
stock dump pipe $10
r32 turbo $100 if u want u can see what its like before i take it off and put the r33 one on
PLEASE LET ME KNOW IF IM ASKING FOR TOO MUCH CAUSE I REALLY DONT KNOW OF HOW MUCH EVERYTHING WOULD GO FOR, THAT WAS JUST AT STARTING PRICE FROM WHAT I SAW ON OTHER PEOPLES POSTS SO JUST OFFER, IM EASY WITH EVERYTHING.
basically anything u want from an rb25 engine,
the only thing i kept was the turbo,crankangle sensor and coilpacks
theres more that i have missed so just ask and ill tell you if i have it or not
i bought this motor with the intention of building it up again to put into my car but i had
a little accident so need funds to fix up my bodywork.
thank you for your time
can sell as whole for a cheaper price if u want.would prefer it this way saves the hassle.
Location; melbourne south east
contact; pm or 0412-219-552 email is the [email protected]
https://www.sau.com.au/forums/topic/226315-complete-rb25-motor/
is it all in pieces? series 1 or 2?
anyting missing?
cheers
umm i think its a series 1.
i took the turbo, coilpacks and cas.
if i can get the wiring loom ill chuck that in.
the only thing i can think of that is missing is prbly some pipes, here and there, and the brackets that hold the cams down which i am currently trying to look for now. somewhere in the workshop
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
