hi guys the block and head are back up for sale, i held the head and block for someone for since i posted this so im just gonna put back up for sale
price drop on everything i just want this gone cause its taking up space in the shop.
rb25 head with lifters and valves still untouched$450 now 350
rb25 block $450 now 350
power steering pump $50 sold
A/C compressor $100 now $50
rocket covers both $50 now $30
camshafts intake and exhaust $100 now $60
intake manifold comes with injectors, anything that bolts onto it $150 sold pending payment
exhaust manifold stock $50 now 30
cross over pipe with stock bov $50 sold pending payment
flywheel still in good condition can give clutch as well for
free still in pretty good condition $100 now 50
timing covers and coil pack covers $80 now 50
throttle body $50 sold pending payment
ecu $100
alternator $ 60 sold
wiring loom $ 120 sold pending payment
o2 sensor $ 30 now $10 lol
engine mount brackets no rubber $30? for both sold pending payment
stock dump pipe $10
r32 turbo $100 now $60
i just want this stuff out please dont be hesitant to offer.
cheers tin
  • 3 months later...
    • Did you pay with a credit card? I'd be putting a charge back through then finding a new sparky to sort it out.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
