Hi all , does anyone have pics of the turbine side of an RB26 type HKS GT-SS turbo - or the Garrett GT2560R 707160-9 which is suppoed to be exactly the same thing ?
I'm just trying to find out if their turbines are the usual base model Garrett GT25 BB turbine style - 11 bladed and the fronts of the blades lead forward - you'll know what I mean if you've seen them .
The Garrett maps of these turbos (CHRA no 446179-65) look pretty good BTW .
Cheers and thanks , Adrian .
https://www.sau.com.au/forums/topic/226432-gtr-gt-ss707160-9-turbo-pics/
I can get some for you tonight if you still need 'em. got a pair of HKS GT-SS at home. and another set on the 32 in the garage. :laugh: they are pretty good. spool up pretty hard. 15psi at 3700rpm.
Yes Beer Baron that would be much appreciated .
I've been reading up on small/medium sized Garrett GT25/28 based turbos because I need something smallish for my daily dinosaur Subaru Leonie RX Turbos engine .
I looked through the maps on the turbobygarrett site and it looks to me like the 707160-9 turbo is exactly the same as the HKS GT-SS GTR turbo - except possibly the waste gate actuator .
Could you possibly confirm for me that the GTR GT-SS turbos ID no's are 707160-9 and or CHRA no 446179-65 .
Also interestingly the compressor wheel OD is slightly different (59.4mm 56T) to many BB GT25/28 based turbos that usually have 60.1mm OD 60/62/63 trim wheels . It makes me wonder if it was a special cooked up by Garrett at HKS's request .
I'm also going to talk to Brett at GCG to see if its practical to fit the lighter/larger trim GT28 NS111 turbine to this cartridge and use the more common SR type GT28BB turbine housing . These housings are a little wider at the inlet than GTR ones and the mounting holes are plain rather than threaded for RB26 apps .
I dont suppose I could talk you into showing us a pic of the compressor wheel with the housing removed ?
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
