Open Cruise 5th July
I came, I saw, I froze. Good Northies run, I skipped out on the Garden City stop.
That was you I was talking to? Oops! Didnt even realise. haha
Was a good run! Good to catch up with a lot of people I havent seen before, met some new people. Good map as well.
