i have some of these on my car, i'm running -3.3 at stock ride hight (yes, arms before shocks/springs was the wrong way to do it). I'm not sure what caster i'm running (got cusco adj rods).
You will pick up another 1.0 degree to 1.25 degrees when the height is optimised.
Cheers
Gary
  • Replies 56
Hey SK, sent a PM a week ago regarding these but you're probably busy.... you taking payment yet?
No need for payment yet. Still a few left to go, I am working on the manufacturing timetable at the moment. More news later in the week.
Cheers
Gary
I have been speaking to the various component suppliers and we have agreed a delivery date of Monday 3rd November. That will means deliveries will start from Tuesday 4th November. They will progress in the order in which payment is received either transfer to the Superior Suspension Pty Ltd bank account or by credit card, call me at work on 02 9603 0100 for details.
I have pencilled in the following guys;
nisskid
whitegtst
psymon
robbieraver
beer baron
cameronbnr32
Duncan
cam
rthirty2gtr
bnr#@
jonn
Cheers
Gary
