Wanted: Water to air (liquid) intercooler. Looking for an ST205 celica one, but aftermarket is fine
Item Condition: Must be in good condition. No dents, cracks or anything that will affect performace.
Price and price conditions: Depends what's you've got!
Extra Info: Also, after the heat exchanger and pump if available
Contact Details: PM me here or post in this thread.
Delivery & Conditions of Delivery: Freight is fine, but pick up preferred so i can inspect.
https://www.sau.com.au/forums/topic/226795-wtb-waterair-intercooler-setup/
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
