  • Replies 212
Originally posted by TIMMMAYYY
ohh no u have kids?
uhh ohh
That means ur married? OHH SHIT
:bahaha: :uh-huh: :cool:
Must say it make life interesting, but at least she is understanding and supportive when I want to do more mods to the car - I think. Actually, I am not sure she has any choice:D
Hahah Steves an ol bastard haha!
Man my gf is ok with the car, i was excited about my dyno and trying to explain to her wat it all meant. She said did u get a graph in which i burst into laughter. Silly GF.
OK friday nite it is.
Me
Steve
Timmy
Hippy HAHHA u better come!
Miss*33
etc etc
Lets do it.
Well im not organisin it. I just suggested. Make it around 9 me thinks!
Matt, the clutch is weird, i cant tell whether or not it is slipping, yeh the power feels like it isnt getting to the wheels properly, i dont know how to explain it thats why i need someone else to give it a go and see what they think.
I wont be able to make this one..
BUT for you guys on boosted's comment about having a cafe in between.. when we have had cruises in the past we have stopped at Villi's cafe just off south road, cos its not in town and you can park ya cars all over the joint. And they make yummy foods.
Its just a suggestion for ya's.
Erica.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
