  • Replies 212
Can someone pls PM me the details, how about a hills/S E Freeway cruise this time - I know a pretty good road up my way, perfect for a cruise... And you can still fit in the cafe thingy too.
BTW, is the Sunday cruise still on or has it been axed, would rather a Sunday cruise than a Friday nighter.
A have a rough map of a good cruise route (as above) so if anyone's interested PM me your email and i'll send it through, and you can tell me what you think.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
