Item: RB25 engine/box/loom ecu package
Age: out of a 96 S2
Condition: very good compression around 155 through all cyls
Price:$2900o.n.o
To Fit: (What car) what ever you want really :P
Contact:me on here
Comments:only missing turbo and fan, but see below, has approx 120K on the clock timing belt changed at 108, will come with new waterpump,
Item:Sliding performance High flow RB25 turbo
Age:around 8 months since build
Condition:excellent no shaft play what so ever
Price:$700
To Fit: (What car) Rb20?25
Contact:me on here
Comments:i believe it uses a vg30 rear housing, the ultimate in legal turbs has made 264rwkw!!!
Item:Greddy STYLE plenum and 80mm billet throttle body
Age:NEW
Condition:good
Price:$440
To Fit: (What car)RB25
Contact:me on here
Comments:the plenum has had the adapter for the throttle body already welded on!
Item:Splitfire coil packs
Age:unsure
Condition:very good!
Price:$400
To Fit: (What car) Rb25
Contact:me on here
Comments:these are to suit S1 i was told but i also have the s1 coilpack loom, which you can use on the S2 if u use the s1 loom.. anyone confirm?
Item: RB25 cometic metal headgasket 1.3mm standard bore
Age:new
Condition:new
Price:$260
Contact:on here
Comments:ummm yes its a headgasket...
Item:RB25 stainless mani
Age:new
Condition:new
Price:$150
Contact:on here
Comments: looks to be a ebay special comes with turb to mani gasket
Item:greddy timing belt
Age:new
Condition:new
Price:$140
Contact:pm on here
Comments:
any questions just hook me a pm
Cheers,
Danny
Edited by shy_s6
  R32Abuser said:
So whats the go with separating? will you on hte engine package?
if so, you have my pm on what im interested in
i want the box so if u want the engine were both in adel so we can work something out?
hehe
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
