Hi..
My steering wheel has become heavy to such extent where it now feels as though there's no power steering at all. There's plenty of oil in the powersteering oil level but I'm leaning to think it might be simply due to power steering failure? Then again, there's always the possibility of steering rack failure?
Any ideas and who should i take it to?
https://www.sau.com.au/forums/topic/227354-steering-wheel-is-really-heavy/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
