This Sunday at Fairbairn - 2 lapper - Who's coming?
I'll be there in the open wheeler, Mark in the GTR
I'm guessing Jeno and Jo wouldn't miss it for the world because Jeno is trying to keep up with Jo's PB achievements (she's a star and well... he's just gay)
I think Keith will be there... who else entered?
https://www.sau.com.au/forums/topic/227508-hillclimb-this-sunday/
  • Replies 57
Mark doesn't like driving the open wheeler? or you wont let him?
You can't change driver easily, he won't fit i.e. foot pedals are set for me and harness is not adjustable without almost taking the walls out.
I planned it that way :thumbsup:
I will be there... Waiting to get my ass kicked by mark. :P
I don't think Mark's driven this year at all *guilty look* and you'll have your wakie day tomorrow to warm up, you'll do great. Need more Skylines there though, those EVO's kick our butts out there LOL
What time please.
Racing starts immediately after the drivers briefing at 9am, they break for lunch at approx 12 (for the flag marshalls) and racing finishes around 4ish. Pit Stop Cafe open from about 8am and runs all day selling sausage sandwiches (egg and bacon rolls at brekky only) and cold drinks, chocolates etc.
Spectators free.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
