Item:r33 stock turbo
Age:unknown
Condition: very good - minimal/ no shaft play
Price:$250 ono
To Fit: (What car) r33 skyline / 32
Contact:Anthony 0433447630
Comments:
call anytime between 9am -9pm
Edited by R33GOD
anyone?
Is it series 1 or 2? I'm told series 2 has plastic compressor wheel... :) Also do you know the approx. km's?
Edited by partyboy73
not plastic. Ceramic.
Exhaust wheels are all ceramic as standard but some series 2 had plastic COMPRESSOR wheels.
a nylon comp wheel on series 2 ;)
this is from a series 1
Touche` :) ..unfortunately I'm after a series 2 otherwise I would snatch up this bargain. Good luck with the sale dude :)
Age:unknown
Price:$250 ono
Comments:
Gday, if you've still got the turbo and its definatley off an r33 i'll grab it ???
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
