1) if they are installed properly, they are very good and will support over 600hp.
2) seen them from about 400 - 550
3) They are a bit tricky to get in, some of the fittings can be hard to find. If you do a search, there is a good thread that covers installing pumps not too far back.
What sort of hp are you chasing? Cos there are some other good options available that are cheaper and easier to install.
https://www.sau.com.au/forums/topic/22787-bosch-044/#findComment-488910
Do they have a mounting bracket that sits the 044 pump properly in the right spot or do they re-use the old bracket? Because mine is a little bit mangled :) I wouldn't mind buying something that puts it in the right position. At the moment I'm contemplating running a longer hose to pick up the fuel from lower.
https://www.sau.com.au/forums/topic/22787-bosch-044/#findComment-489988
Originally posted by INASNT
$320 with all the fittings. Just got mine installed. If u know em then u get the good price otherwise :shake:
jee u must know them well,i havnt seen them under $300 and i have bought a few,just bought 2 for my r32 and cost me $600 and then to fit intank and do it properly you need about $75 in fittings and also labour to fit into the tank.
u paid $320 for a $450 minimum job,are u sure its not an 040 or another brand pump.
https://www.sau.com.au/forums/topic/22787-bosch-044/#findComment-498336
Guest INASNT
i got a whole bunch of stuff done so the labour costs aint that much just for the pump
https://www.sau.com.au/forums/topic/22787-bosch-044/#findComment-498629
No surge for me unless I'm below the empty line on the gauge (<8-10 litres). I know why it's doing it though, it's because the pickup doesn't go as far down into the tank because the pump is in a different position. One day when I can be bothered I'm going to take it out and put in some longer hose so it gets the fuel from further down in the tank.
If yours is doing it with half a tank you probably have a dodgy install. Have you got the original pick-up fitted to the bottom of the pump or is the fuel going straight into the pump?
https://www.sau.com.au/forums/topic/22787-bosch-044/#findComment-499190
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
