And also, the Z32 will support air flow up to around 55-60lb/min. So if you're making that kind of power, I would suggest changing to the new VIPEC ECU or a MOTEC/AUTRONIC/HALTECH and stop mucking around with a system that is not going to get you anywhere
https://www.sau.com.au/forums/topic/227873-nissan-q45-afm/#findComment-4010364
Engine
Rebuilt Engine
Ported and Polished Cylinder Head
GREDDY Racing Timing Belt
GARRETT GT35R .86 Ported Shroud And Chrome Housing
Topmount Exhaust Manifold
TIAL 43mm Wastegate
HKS Downpipe
HKS Ground Cables
COMETIC 1.5mm MLS H/G
TOMEI Procams 260 Degree 10.25mm Intake Camshaft
TOMEI Procams 260 Degree 10.25mm Exhaust Camshaft
TOMEI Procams 10.25 Lift Type B Valve Springs
TOMEI Forged Solid Lifters
TOMEI Cam Pulley IN/EX
TOMEI Adjust Shims
SARD 550cc Fuel Injectors
NGK Iriway 8 Spark Plugs
Z32 AFM
APEXI Power FC Standalone
Engine Exterior
HKS HYPER Exhaust System
HKS Type R Intercooler
HKS Oil Cooler
HKS Ground Cables
CUSCO Oil Scavenger
NISMO Fuel Regulator
WALBRO 255L/H Fuel Pump
TEIN FLEX Coilovers
TANABE SUSTEC Strut Tower
OS GIKEN Twin Plate Clutch
BLITZ SUS POWER Air Filter
I was making 413hp on wheels on 1.7 bar of boost with the setup above.
Somehow i f***ed my oil pump and bearings where i have predicted it'll happen.
Now im in a process of rebuilding my block with Wiseco pistons, GTR rods, ACL bearings and a JUN oil pump.
Im looking for a Q45 because my airflow reading is at max. Im currently using PFC and if possible i would like to upgrade the PFC to a FCON.
Im searching for a complete set of RB26DETT plenum and runnersas well.
https://www.sau.com.au/forums/topic/227873-nissan-q45-afm/#findComment-4010768
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
