I recently imported my Trust 6 spd gtr, and it came with a piggyback M's fuel and timing management. I have never heard about this product, and everything is intertwined into it. M's fuzzy boost controller.
Im planning on ripping it out, convert the wiring harness back to stock and go PowerFC.
any thoughts ?
https://www.sau.com.au/forums/topic/227922-ms-fuzzy-boost-controller/
I have had a few of those... never got them to work.
Just bin it and get a late model boost controller in my opinion.
is it just a boost controller? or fuel and timing?... does it intercept wires to my ecu or just read wires?
    • How do you propose I cable tie this: To something securely? Is it really just a case of finding a couple of holes and ziptying it there so it never goes flying or starts dangling around, more or less? Then run a 1/8 BSP Female to [hose adapter of choice?/AN?] and then the opposing fitting at the bush-into-oil-block end? being the hose-into-realistically likely a 1/8 BSP male) Is this going to provide any real benefit over using a stainless/steel 1/4 to 1/8 BSP reducing bush?
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
