Item:Jim berry full monty race clutch
Age:Brand new unused
Condition:new
Price:$1500
To Fit:Vl turbo, R32 gts-t, R32gtr, R33gts-t+ some others models (What car)
Contact:Corran 0433 082 998
Comments:4,000 pound clamping force.
5 puck.
Chromemoly flywheel with a cast iron insert made in to flywheel where clutch pads run, for exxtra grip.
Is to suit a vl turbo, r32, r32 gtr, r33 gts-t. is a push type clutch.
Is unused and still in the box, retail cost is $1900 selling for $1500 + postage.
Same clutch as Maatooks use to run 9.5 sec quarter mile in a vl turbo and handle over 500rwkw.
https://www.sau.com.au/forums/topic/227969-jim-berry-full-monty-race-clutch/
  • 2 years later...
