vid wasn't that bad grant! perhaps i would have preferred to see a little more of the road infront though but that's just being picky
looks like you had a ball! need some more front end grip and power by the look of things though :D
Edited by M I K E
lol i agree
i kept understeering like a bitch
i really think if i put another 10psi in the tires in the back it would have been fine, but by the time i decided to, i caught on fire lol.
but really, i shoudl be at 16s in the back....but im stubborn
WTF did you have strapped to the roof rails, Grant?
Yeah, next time you'll have to angle the on-board camera to face further forward, it should give a better perspective of what you're trying to do and how the car is reacting to your inputs.
Other than that, it's good to see a wagon out drifting!
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
