I have a S1 R33
Setup atm
Stock RB25 Motor
Custom Plenum
T66
Top Mount Manifold
660cc Injectors
Microtech Ltx12
50mm Ext Waste Gate Venting Atmosphere
3" Exhaust
Was good till the weekend when I blew the motor, Looking to build 30/25 now and wanted to know some shops
in QLD and between Brisbane and Goldy who could give me some advice. I have been looking on the Spool website
at there parts.
How will the T66 go with the 3L Has anyone used this before? It was not coming onto till 5 on the stock 25.
I want to full forge the motor so I wont have to do it again anytime also looking between 500-600hp.
Any help anyone could give would be great. I'm going to keep reading and researching for a month or so
before I go and build it.The car is a street car but only driving on weekends, so I'm after some big cams and fuel
does not bother me.
Edited by Buddah
https://www.sau.com.au/forums/topic/228082-r33-rb3025/
Where are they I have not heard of them before. Also anyone got idea what cams I should run? Thinking Tomei Poncams.
So far I have made list of parts.
SPOOL FORGED CONRODS
CP FORGED PISTONS
COMETIC MLS HEADGASKET
ACL RACE SERIES MAIN BEARINGS
ACL RACE SERIES BIG END BEARINGS
SPOOL RB CAM GEARS
Tomei Poncams
Oil Pump *not sure what type*
Water Pump *Not sure what type*
Also Head Rebuilt
If you have any advice or better ideas please feel free to let me know =)
Edited by Buddah
https://www.sau.com.au/forums/topic/228082-r33-rb3025/#findComment-4013844
    • About $4k brand new, available from vendors in Oz, or via an importer from Japan. Although that is for an R34 box, so you also need to buy the push clutch front plate (brand new from Nissan) and swap that over, and drill the bellhousing for a push clutch slave cylinder.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
