Hey guys,
I recently installed a r33 gtr fuel pump into my r33 gtst.
The problem is when i pulled my original one out i dont recall it being held into place by anything. When i put the gtr fuel pump in i couldnt find anywhere to clip it, so i put it in the way i thought i pulled the original one out.
It is a louder pump, i was aware of that but it also makes strange noises at lights with half a tank of fuel.
My question is, tomorrow should i clip the bracket onto something (if theres something its suppose to be held onto) or just leave it?
Cheers in advanced.
https://www.sau.com.au/forums/topic/228699-r33-gtr-fuel-pump/
its a bit hard to actually see it, but the whole assembly drops down toward the front end of the tank. the bracket slides into a bit of plastic near the top and the pump hangs down to the bottom. its not the pump that is connected, but the very top of the bracket itself. post a pic of what you took out so we can tell you what happened i dont have pics.
its likely that your pump is just swinning around hanging off the fuel hose. it will be very noisy when it hits the side or if it rises above the fuell level.
Hard up against the inside front wall of the tank, there is a large flat whitish plastic fitting. The metal bracket from the fuel pump slides into this and clips or locks in place.
Have good look and you will see what I mean, sounds like you didn't clip yours in to me.
Easier to do it with 1/4 tank or less.
This might help, its for a 32, but I think they are the same.
http://www.skylinesaustralia.com/forums/R3...ati-t55337.html
I originally attempted this with a full tank of premium, once alot of petrol started pissing out onto the ground i thought HMMMM thats not a nice way to treat golden liquid.
Anyways i dont drive it too much through the week so tried thrashing it around for a bit and ended up doin it with 3/4 tank of fuel which still didnt help plus it was getting dark but i did it anyways.
I know what both of you are saying which helps alot because i had my hand in there and thought i was looking for nothing and making my premium petrol not so premium anymore.
Ill have another crack at it tomorrow now that i have around half a tank or less and will actually be able to see with daylight :D .
Cheers fellas.
Its an easy one to think you got it right and then here the tell tale extra noise of the loose pump and the clunks as you go round a corner etc
I actually had a dud pump and a so called reputable skyline shop changed it, only to miss the bracket. I ended up having to redo it myself later at home and seat the bracket home. So even the 'experts' can get it wrong. But you'll here [or should here] a click as it seats home. A bit of sunshine into the boot helps heaps, park your car so the morning or arvo sun is beaming in.
Yea i did it today, i could actually see where the bracket clips into but the gtr pump wouldnt let it go in so i had to bend it a little.
I could only get it to go in about 1cm, it just wouldnt go anymore so i left it like that. It still made the same noises when sitting at traffic lights so im not sure if its normal or not but as long as it drives then who really cares i guess.
Thanks alot for the help i appreciate it.
aha that may be the fake one... there is one spot which is very similar but it wont go in properly, the actual thing is very close but a bit higher up. I think it may be a case of take it directly up 5 cm or so.
the pump needs to go in a bit crooked, then once its down the bottom you can pull it up and into the bracket, thats why one prong thing is a bit longer than the other on some.
i remember doing thse now and although its great if everything goes well, sometimes you just cant get it in- like all good things in life lol
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
