  • Replies 199
Well its good to see you guys had a good time. Im extremely regretting not coming. I decided to go motorbike riding instead, but got shown... Bike died a good 1.5 hr walk from our farm and i had to push it all the way, sucked soooo bad. Think i blew the ring on the piston cos seems to have verry little compression :(
Anyway heres my imput Adam Clean his wags last night:
And my photo from today:
was good cruise good fun. didnt go down at 6 to c if any one missed the change of plan :( where do we all wona go for the next 1? sunday arvo seems to work well for a fair few people with enough notice!... :laugh:...
Hey Guys,
Was a great day for a cruise, weather turned out to be fantastic and Nene got some great shots of the cars. Didnt get a chance to chat to everyone so we definitely have to do it again!
My vote is to start at a similar place again and head to mannum through chain of ponds and birdwood, its an awesome drive with some fun roads! My thoughts would be to start around 10:30ish, and take our time and have lunch in mannum. Its a straigh forward run, i use to do it in an hour towing my jet ski! Who would be in for that?
And how tough is the pic of 3 black 260's! :sleep:
I can make it to birdwood in 11 minutes from my house. AHEM.
May i lead this next cruise? know the roads like i know my umm.... anyway.
Starting at same location and leaving around 10:30 is a great idea. Making it a saturday would ensure less traffic coming up the hill too.
I'm thinking newton - birdwood for a stop, then onto mannum for lunch(looong roads to stretch the legs), back down the freeway with a wind down eagle on the hill for a finish in the early arvo?? I'll start a new thread tonight.
Dunno if i could handle FOUR black Rs260s :/
Nigel.
4 black 260's and a white one as well!! :D
One of the black ones being a series 2 also :D Would be good to see your car again Craig.
BTW Nene, jet came home. Everyone happy. :/
Your photos look awesome nene! very artistic eye you have there....me and you should organise the next photography cruise together :/
Im thinking my next cruise i organise, all stags are welcome too btw lol, maybe head down murray bridge or something different like that.
See what people think?
Btw the shots i took of your stag have turned out great :D
i took some pics of mine after the cruise... are mine artistic? :rofl::D
http://i78.photobucket.com/albums/j85/Silh.../Picture486.jpg
http://i78.photobucket.com/albums/j85/Silh.../Picture480.jpg
Edited by Silhouette31
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
