Hi, just made the last day, I'll dd the money but it won't be in till Monday or Tuesday if that's ok? I won't be back in Adel till Sun. PM me if it's no good.
hoodie/jacket: hoodie
username/real name: Matty
name in caps or not: As above
colour: navy
how many: 1
Thanks
  • Replies 665
Posted Images
Hey there, sorry about the last minute order. Forgot to put it in earlier :)
hoodie/jacket: jacket
username/real name: fullyhyper
name in caps or not: same as above
colour: red
how many: 1
= $56.00
Will transfer money now. PM me if thats ok - because the money might not go through until after the weekend - otherwise i can try and get to Villi's tonight to give cash in hand? :O Let me know ASAP. Cheers.
Ahh red Charmaine! i was gonna get a red one, decided against it, but ill get to see yours and ill decide whether or not i want one!
Haha yeah well my (FREE :O) nissansilvia.com one is black so i thought i would go something different :)
i wear the nissansilvia.com one all the time...won it at the Megacruise haha...was sposed to win a drift pineapple?? And when i told them i had a ford laser they gave me a hoodie instead :) hehehe.
Is it too late to just chuck the money in Adrian's bank account? Or would he rather cash in hand tonight?
Cheers :D
ey, ive already previously posted but im changing what i want written from 'matt' to 'SNIPER'
Type: hoodie
Colour: Black
caps or no caps: Caps
How many: 1
im a slim build but all my quiksilver stuff is large so im guessing its the same...
ive given chad the money (DSTROY) so he should be payin tonight at villis for me, let me know
hoodie/jacket: HOODIE
username/real name: SLYR 33
name in caps or not: CAPS
colour: BLACK
how many: 1
=$53.60
username/real name: -
name in caps or not: -
colour: BLACK
how many: 1
=$50.00
hoodie/jacket: JACKET
username/real name: MEL
colour: BLACK
how many: 1
=$51.80
All together ill transfer $155.40 over tonight if thats ok with you mate.
Hey there, hopefully my money got passed on.
I gave $56 to SLED so if it wasnt passed on im hunting you down SLED ;)
hehehe i just wanted to use that emoticon :)
Yayyyy hoodies!!!
Btw lost my hockey match :) devvvvvvs.
Its a bit late. That may not clear until Tuesday, so its up to the lads if you're on the first group buy. Never fear tho, they were saying tonight it was a great result, so another group buy should be on the cards.
I gave $56 to SLED so if it wasnt passed on im hunting you down SLED :)
Yeah, Sled passed it on for you. ;)
You're in. :)
ppl who havent paid MUST give me cash directly either sat night sunday night or monday morning or else they miss out!!
i will not accept any money after midday monday!
bank transfers recieved will be returned back!
cheers
You're in. :)
Yewww! :D Cheers for that SLED!
You should have come out to Vilis instead then :)
Haha i know! Could've got a maaaaadd feed! :) Oh welll. Next time. :D Which will be when we pick them up? :D
ps... im not gonna go chasing up who havent paid!!
if i dont have cash u miss out! bad luck! u have had 2 weeks!
any problems let me know!
thanks!
now to trader rate everyone hahahahah
You've been more than fair Adrian. ;)
People know the drill ... you order and pay in a timely fashion before the deadline. Otherwise you hold up those who have paid, and none of us want that in this case.
Kudos to you guys for getting the hoodies organised. Can't wait :)
paid..
Damo
me
neners4
ryanrb25
heslo
drd-00f
bunny33
eddyfier
flick
jonnyboy89
vinnie32gts4
monkeyboy
dstroy
bezender
min_r32
gtr-r32
jugz
type vu
musky
sambo33
imports13
ruby
ndawg
cronic
r32skyline93
hi2u
slammed 32
jack88
inh3eavan32
usmair
fabs32
lukeenr34
gijoe
frankyp11
johnzey
nightcrawler
krishy
sklyn
on the ranch
inline6
foxycleo8
scottydoo
lin33r
260tech
fishpaste
sled
fullyhyper
madaz
issac
any probs... 0433290801 [email protected]
cheers
Yeah i wont transfer it over, ill just wait until next one hehe
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
