Item:
1 - 180sx Rear Bar
White Comes with Irons
2 - Aftermarket Front Bar S13 (not sure which brand)
Black, Damaged, Good For Track.... What you see is what you get
(MINUS Cusco Numberplate Holder)
Still mounts fne just lst that corner
3 -S13 Siliva Aftermarket Boot Spoiler
Has Brake Light Wires
naVan Brand
4 - CA 180SX Hatch Spoiler
(Gunmetal Grey - suit Respray)
5 - 180sx Tail Lamp Panel
Black
Twin Cam Turbo Intercooler Sticker
6 - CA Stockies x4
No Tyres
No Centre Caps
7 - 180sx CA Seats + Rails
Dusty but good condition
One Ciggie Burn On Passenger Seat (see pic)
8 - Silvia Steering wheel
Will come with center (if i find it)
Clear that defect!
9 - R33 4 Door Tail Lights
With Center garnish for boot lid
Slight scratchs
10 - R33 Complete Handbrake and lines
11 - R33 Dash Great Condition!
no vents
12 - r33 RB 25 Timing Cover
13 - S13/180sx Glove Box
Immac!
14 - Z32 AFM
No Plug
15 - R33 Rb25det Exhaust Manifold (stock)
Items can be picked up from western subs
Contact Via PM or Here
Cheers
Condition: All in used condition but pretty good for there age
Price:
1. $40
2. $30
3. $30
4. $15
5. $20
6. $150
7. $100
8. $40
9. $450 ono
10. $80
11. $150
12. $30
13. $40
14. $200
15. $30
To Fit: Silvia 180sx R33 and various
Contact: PM or novak-86 @ hotmail.com
Comments:
https://www.sau.com.au/forums/topic/229056-loads-of-parts-for-sale/
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
