34 GTT, and buy from us while you're at it.
hey wonderin wat would be the best way to go with 25K
buy a better model earlier version (gtr)
or get a newer 34 turbs
any suggestion would be appreciated
thnks in advance
https://www.sau.com.au/forums/topic/229130-what-to-buy/#findComment-4028547
Hmm, hard call that eh?
i) a GTR (R32) that won Bathurst in '91 & even with a weight penalty in '92
ii) a GTR (R33) that lapped Nurburgring in less than 8min (one of the 1st if not the...)
iii) a GTT (R34) which has won the NZ Targa in '06 & '07 against Porsches, EVOs, STis, GTRs etc
Realistically, it depends too on what you intend to do withe the car,
a) road car
b) circuit car
c) drag
Assuming with your budget, you'll use it as a daily. So I can only help by voting for ii) or iii)
All the best with your trouble-free purchase & enjoy!
Terry
https://www.sau.com.au/forums/topic/229130-what-to-buy/#findComment-4037797
a) road car
b) circuit car
c) drag
Terry
thanks man ive had three previous cars all white and all were f*king cursed either that or i know how to pick a nice sour ripe lemon haha but with this forum i got seven pages of stuff to check for so hope i get a good'n this time around
https://www.sau.com.au/forums/topic/229130-what-to-buy/#findComment-4037878
Hey!
You're very wise to make up a list of check-points!
It's hard not to get excited as you inspect a potential 'good buy'. So, at inspection, hand over your check-point list to your mechanic friend; as you inspect for rust (on undercarriage/under boot carpet/seat rails/engine bay), accident damage (& whether or not it's been fixed properly), uneven tyre wear, check if the owner is a liar by asking him/her if they race the thing (as you check if the tyres are feathered/rippled), sludge under and around the oil filler cap, logs/receipts, wear on carpet and seat bolsters (that should correspond to the odometer), oil seepage (and from where), quality and smell of oil on the dipstick, cracking on driveshaft boots, missing or damaged items that are on the specs, windscreen cracks/chips, sun damage to paint/top of steering wheel/rear seat ridge/parcel shelf.
And this is all before you turn the key on a cold engine. Now you can pick up the 100s of messages that come thru your seat and steering wheel!
Cheers, T
https://www.sau.com.au/forums/topic/229130-what-to-buy/#findComment-4038018
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
