:P
* Afrikaans: praat jy Engels?
* Albanian: a flet anglisht?
* Arabic: هل تتكلم الانجليزية؟ (hal tatakállam al-’ingilizíyya)
* Bambara: bε angilekan men wa?
* Basque: ingelesez hitz egiten al duzu?
* Bosnian: da li govorite engleski?
* Bulgarian: говорите ли английски? (govórite li anglíjski?)
* Catalan: parles anglès?
* Chinese: 你会说英语吗? (Nǐ huì shūo Yīngyǔ ma?)
* Czech: mluvíte anglicky?
* Danish: taler du engelsk?
* Dutch: spreekt u Engels?
* Faroese: tosar tú enskt? (informal), tosa tygum enskt? (very formal)
* Finnish: puhutko englantia? (informal), puhutteko englantia? (formal)
* French: parles-tu anglais ? (informal), parlez-vous anglais ? (formal or plural)
* German: sprichst du Englisch? (informal), sprechen Sie Englisch? (formal)
* Greek, Modern: μιλάς αγγλικά; el(el) (milás angliká?) (informal), μιλάτε αγγλικά; el(el) (miláte angliká?) (formal or plural)
* Hungarian: beszélsz angolul? (informal), beszél angolul? (formal)
* Icelandic: talar þú ensku is(is)
* Indonesian: bisa bahasa Inggris?, apakah anda berbicara bahasa Inggris?
* Italian: parli inglese? (informal), parla inglese? (formal), parlate inglese? (formal or plural)
* Japanese: 英語を話せますか? (Eigo o hanasemasu ka)
* Jingpho: Ing-galik ga shaga ai i?
* Khmer: តើអ្នកនិយាយ​ភាសាអង់គ្លេស​ទេ? (ter neak niyeeay phiəsaa-âŋglee dtee?)
* Latin: Anglice loquerisne?
* Malay: boleh anda cakap bahasa Inggeris?
* Maltese: titkellem bl-Ingliż?, tpaċpaċ bl-Ingliż?
* Norwegian: Snakker du engelsk? no(no)
* Occitan: parlas anglés ?
* Polish: czy mówisz po angielsku?
* Portuguese: fala inglês?
* Romanian: vorbiţi engleză?
* Russian: Вы говорите по-английски? (Vy govoríte po-anglíyski?)
* Spanish: ¿Hablas inglés? (informal), ¿Habla inglés? (formal)
* Swedish: talar du engelska?
* The land of goat sphincter rings: İngilizce konusabiliyormusun?
* Ukrainian: ви говорите англійською? (Vy govorite po-angliyskoyu?)
Edited by Topaz
https://www.sau.com.au/forums/topic/229407-tunimg/#findComment-4032875
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
