primordial how simple is it to do an ecu reset??
thanks
This is how I reset the ECU on my Subaru. I image the same will work. Its not the proper way to do it, but its by far the simplest. Its the simplest because I don't remember the other way.
How to reset the ECU, battery dance styles.
NOTE: Do this on a "cold" engine. Leave it sit overnight and do it in the morning.
1. Disconnect the negative battery terminal cable for 45-60 minutes.
2. Reconnect the negative battery terminal cable.
3. Turn off all your accessories.
4. Start the car, but DO NOT touch the throttle at all.
5. Let the car idle for 10-15 minutes, or until the car is at normal operating temperature. Again, do not touch the throttle.
6. Turn the ignition key to the "OFF" position. That's it.
https://www.sau.com.au/forums/topic/229413-wtf/#findComment-4032889
thanks
take the battery off and leave off for 24hrs
but sounds like you have an electric short some where. might be best to take it to an auto electrician
Yeah as Mitch said - your best bet is to contact an auto electrician.
There's almost no way the ECU can decide to start the car itself... its an electrical circuit that is most likely shorting somewhere and starting the car... Just thinking though, how could the car possibly have run the starter motor for the specific amount of time needed to start the car? If it was properly shorted it would have grinded the starter motor into oblivion when the car started and the starter kept going..
Very odd problem! :P
https://www.sau.com.au/forums/topic/229413-wtf/#findComment-4032920
yer very true i just had a quick look at sum stuff on car and the turbo timer is not a turbo timer its wats left of a remote start alarm but only ignition loom runs through it no extras.and its all jap writein so dont have a clue wat its set on. i also droped hand break 2 kill it and it stoped i traced one wire 2 nand break switch.
Edited by skyl1ne r33
https://www.sau.com.au/forums/topic/229413-wtf/#findComment-4032934
That hurt my head to read and I still don't understand it :P
https://www.sau.com.au/forums/topic/229413-wtf/#findComment-4033067
Well it sounds like you're onto it now anyway. Get it removed. It's probably more of a security risk than a help.
https://www.sau.com.au/forums/topic/229413-wtf/#findComment-4033157
whatever you do, do not cut the handbrake wire, unless you know how to remove that alarm, and get the car sorted. ( cutting the wire will disable the car and you won't be able to start it. had this on my old car took me ages to find)
if not take it to an auto electrician, or call a Mobile alarm guy and they should be able to take it out.
https://www.sau.com.au/forums/topic/229413-wtf/#findComment-4033203
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
