primordial how simple is it to do an ecu reset??
thanks
This is how I reset the ECU on my Subaru. I image the same will work. Its not the proper way to do it, but its by far the simplest. Its the simplest because I don't remember the other way.
How to reset the ECU, battery dance styles.
NOTE: Do this on a "cold" engine. Leave it sit overnight and do it in the morning.
1. Disconnect the negative battery terminal cable for 45-60 minutes.
2. Reconnect the negative battery terminal cable.
3. Turn off all your accessories.
4. Start the car, but DO NOT touch the throttle at all.
5. Let the car idle for 10-15 minutes, or until the car is at normal operating temperature. Again, do not touch the throttle.
6. Turn the ignition key to the "OFF" position. That's it.
https://www.sau.com.au/forums/topic/229413-wtf/#findComment-4032889
thanks
take the battery off and leave off for 24hrs
but sounds like you have an electric short some where. might be best to take it to an auto electrician
Yeah as Mitch said - your best bet is to contact an auto electrician.
There's almost no way the ECU can decide to start the car itself... its an electrical circuit that is most likely shorting somewhere and starting the car... Just thinking though, how could the car possibly have run the starter motor for the specific amount of time needed to start the car? If it was properly shorted it would have grinded the starter motor into oblivion when the car started and the starter kept going..
Very odd problem! :P
https://www.sau.com.au/forums/topic/229413-wtf/#findComment-4032920
yer very true i just had a quick look at sum stuff on car and the turbo timer is not a turbo timer its wats left of a remote start alarm but only ignition loom runs through it no extras.and its all jap writein so dont have a clue wat its set on. i also droped hand break 2 kill it and it stoped i traced one wire 2 nand break switch.
Edited by skyl1ne r33
https://www.sau.com.au/forums/topic/229413-wtf/#findComment-4032934
That hurt my head to read and I still don't understand it :P
https://www.sau.com.au/forums/topic/229413-wtf/#findComment-4033067
Well it sounds like you're onto it now anyway. Get it removed. It's probably more of a security risk than a help.
https://www.sau.com.au/forums/topic/229413-wtf/#findComment-4033157
whatever you do, do not cut the handbrake wire, unless you know how to remove that alarm, and get the car sorted. ( cutting the wire will disable the car and you won't be able to start it. had this on my old car took me ages to find)
if not take it to an auto electrician, or call a Mobile alarm guy and they should be able to take it out.
https://www.sau.com.au/forums/topic/229413-wtf/#findComment-4033203
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
