94 GTR SKYLINE
Tein Coilovers
Strut Brace Front Rear(Aftermarket)
Apexi Boost Controller
HKS Oil Cooler Kit
R33 GTR Wheels
R34 GTR Turbos
HKS Pod Filters
New Gtr Fuel Pump
Sports S/Wheel
Replaced Injectors/AFM'S
3Inch Exhaust
Turbo Timer
Alarm
New Clutch Master Cylinder $250
T Clamps On ALL cooler piping $200
Gear Box Removed /stripped and replaced 4 syncro $700
Jamie at JRM Transmissions said the Gear Box was in excellent condition
Extreame 6 puc clutch
CP forged pistons
SONY Stereo
Aftermarket 330km/h Dash
Gun Metal Grey the darker of the 2
Car is in good condition and is very fast
0415562946 thanx....
22k ono
https://www.sau.com.au/forums/topic/229504-r32-gtr-94-model/
Forgot to add it has TCS Traction control system 4wd/2wd switch this lets you put as much traction on the front diff as you like one of the best modificaions you can do to a 32 gtr price $500...
Edited by luke james
Getting new clutch as we speak and will be putting new DBA4000 series brakes front and rear plus SRT pads so price change $22500 ono car will be ready for track days Nothing to spend!!!Very fast GTR!!!
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
