94 GTR SKYLINE
Tein Coilovers
Strut Brace Front Rear(Aftermarket)
Apexi Boost Controller
HKS Oil Cooler Kit
R33 GTR Wheels
R34 GTR Turbos
HKS Pod Filters
New Gtr Fuel Pump
Sports S/Wheel
Replaced Injectors/AFM'S
3Inch Exhaust
Turbo Timer
Alarm
New Clutch Master Cylinder $250
T Clamps On ALL cooler piping $200
Gear Box Removed /stripped and replaced 4 syncro $700
Jamie at JRM Transmissions said the Gear Box was in excellent condition
Extreame 6 puc clutch
CP forged pistons
SONY Stereo
Aftermarket 330km/h Dash
Gun Metal Grey the darker of the 2
Car is in good condition and is very fast
0415562946 thanx....
22k ono
https://www.sau.com.au/forums/topic/229504-r32-gtr-94-model/
Forgot to add it has TCS Traction control system 4wd/2wd switch this lets you put as much traction on the front diff as you like one of the best modificaions you can do to a 32 gtr price $500...
Edited by luke james
Getting new clutch as we speak and will be putting new DBA4000 series brakes front and rear plus SRT pads so price change $22500 ono car will be ready for track days Nothing to spend!!!Very fast GTR!!!
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
