R32 GTR mate.
Have a look at my old one that is being sold at the moment. Drive that and see what a stock setup with a good tune can do.
You have a
low 12 second car with lovely road manners even in the rainy months of the year, unlike the gtst. All for less than $20k drive away.
  • Replies 177
R32 GTR mate.
You have a
Trying to get the power down is half the fun :blink:
32 imo 33 as said before becoming as common as commodores, people spending bulk $ on their 33's and still cant sell them for same price as the standard ones.
32 looks better :)
What's the resale value got to do with anything, 32's are even worse can get them for 10k now fairly modified, old square shape with no curves and crapola interior
sif drive a whale... 32s ftw! :)
Seriously Supras are the damn whale
makes 33s feel small and nimble in comparison
who the hell made that up?!
btw unless Nissan farked up, 33 > 32 ! :P
and stick with your rb20/weak box :D
Edited by R32 Driver
btw unless Nissan farked up, 33 > 32 ! :)
and stick with your rb20/weak box :P
Yes Nissan did fck up... didn't you get the memo?
33s are nimble, heres one on the streets of Japan
So your saying there is nothing good about the R32 other than the body styling ? :D
Pretty much heh. But all those things in any car would make for a lot of fun.
I've driven many 33's from completely stock to pretty done up and I just really don't like the feel of them, which is why I bought a 32 and proceded to throw money at it :D
bubba can I have a drive of your car?
I'd prefer some new suspension in mine, video's from the AHG day tell me stock 33 suspension sucks... but I wanna stop spending money on cars. Fkn cars.
*buys bike*
lol the only people that drive my car other than me are my two mechanic mates, and probably brad.
I would also hazzard a guess that you'd get more of an idea driving Brads' car or another 33 with suspension mods as the 32 is a fair bit different :D
hmmm my R33 is pretty nimble ....it has tein suspension :D hahaha hmmm 32/33's are both getting old but if u think about it with the R33 u get more of a deal e.g updated interior, better gear box/diff/engine just cause it looks like a whale doesn't mean u can't slap a kit on there etc etc lol ryan pass me on the GTRS :D
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
