i blew my clutch today
where to go on the southside of brisbane for clutch?
and what clutch should i get?
want it to handle 350hp?
and no i dont have that much power yet but i would prefer to do it once
what price am i looking at ?
and should i get a lighten flywheel at the same time?
Edited by Turbo 33
https://www.sau.com.au/forums/topic/229747-clutch/
im in sydney so cant help on locations...
but i blew my clutch on monday, im looking at either an os giken or might call Jim Berry. i think he's up in qld. theres a couple of threads on his mad clutches, just search around.
as for your flywheel, you might need to get your existing one machined anyway, if you blew your clutch badly enough you might have torn chunks and put scratches into it.
money wise - maybe around $300 for just a replacement nissan stocker up to around 2 grand for a crazy circuit/drag application. theres a mariad of clutches in between, up to you to decide how much you wanna spend opposed to what quality you want.
https://www.sau.com.au/forums/topic/229747-clutch/#findComment-4038460
are these clutches from slide any good
Heavy Duty 5 Puk Button clutch kit, $439
Exedy (SC) Cerametallic 3 Puk Button clutch kit (330rwkw), $610
and what about this one from just jap
xtremedsbclutchgtst-01.jpg - 850kg Clamp Load
- 25% Increase Over Standard
- Dampened Hub
- Solid Ceramic Facings
- Suit ECR33Detailsspacer.gif SKUXTREMEDSBR33-KNI24001DSBHDQuantity in stock2 item(s) available Price:AUD 530.00
or this one
xtremeclutchgtst-01.jpg - 850kg Clamp Load
- Dampened Hub
- Cushioned Ceramic Facings
- Suit ECR33
Detailsspacer.gif SKUXTREMEDCBR33-KNI24001DCBHDQuantity in stock2 item(s) available Price:AUD 589.00
please help i want my car back on the road and i want it to handle a little bit of drift and drag and not die on me
which one is good i dont know anything about clutches
Edited by Turbo 33
https://www.sau.com.au/forums/topic/229747-clutch/#findComment-4039187
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
