tried wiring new numberplate lights on my r33, had the parker lights on and must have crossed the wires wrong, rear lights went out, the beeper inside the car from leaving the lights on stopped and dash lights went out...
i went to the fuses box and pulled the electric fuses to find it was ok. plugged it back in and the rear lights come back on, dash background lighting come back on and beeper come back on.
thought it was all good until i switched the lights off and they didnt go off, the light warning beeper didnt stop and background dash light still on.
its had me beat whats happining, can someone lead me in the right direction or have any ideas to whats happening
4drftn.
no havent got numberplate lights at the moment.
there was power getting to the numberplate light holdsters, i used a test light to check, but wouldnt light up the bulbs, even after changing the bulbs still nothing. so iv cut them off and attempted to wire another one i got from autobahn.
must have short something out, but didnt blow the fuse... from what iv tried sussing out the wire may have melted into another wire that has a current flow of power even with the ignition off.
so currently (temporarily) i have one of the fuses (electric) out. which disables the dash lights, rear lights when the headlights and/or parker lights are on, parker lights and warning beeper. done this temporarily so my battery doesnt go flat etc.
brake lights still operate once brake is pressed...
Hey mate. Just check to make sure that you didn't bump the fog light switch on the combination swtch. On my wifes 33 4door it has a switch near the end of the combo switch. If that makes any sense.
yes mate, i checked that shortly after it happened incase it was accidently bumped in confussion.
iv been told there could possibly be a relay behind the dash somewhere that could have burnt...
i may have to resort going to an auto electrician as im all out of ideas to what could be causing the drama
g'day mate. i'm an auto elect by trade and i don't think it could be a relay that has fused shut. for a relay to fuse shut you would have melted the wiring first and probably blown the fuse. if it is relayed it is negtive switch to the relay and sends a positive to the light. not the other way round. the original problem u had was just and earthing issue either on the bulb holder or in the wiring harness. the only way u can check if the harness is burnt is to remove the trim round the boot and remove the electrical tape. most melted wires only travel a short distance depending on how long the positive feed was to ground for. when u cut the wires did u notice if there was smoke signals or an electrical smell. if not u didn't melt the harness. hopefully this can help.
Edited by 116.hks
i currently have all boot trim removed from the car, i will take the tape off and have a check, it only sparked for a split second so hopefully the damage isnt far from the numberplate light location.
i didnt smell anything as i had the power off when i cut the 2 wires off. even after it sparked i didnt smell anything.
from what i have described, what are the chances of me having to replace the harness? or would there possibly be another solution or alternative to having the harness replaced?
from wat u have just said if you had the power off ( lights off) then i don't think you have done any damage to harness as such. if you don't mind me asking where are u located. i'm in redcliffe near brisbane. if you live round here i could meet u and check it out for ya. i'm just running out of ideas at the moment. wat u have done could not cause the harness to melt and join a positive to that wire.
that would be excellent only i live in TAS. :(
when i cut the wires everything was off, but when i went to wire it up/ test i turned the lights on and placed one of the wires on and nothing, then the other wire and nothing, then stuipidly i placed both on it which caused a spark.
i should have mentioned earlier... the light i tried wiring is a truck & trailer lamp (with no wiring), not an actuall numberplate light with an earth wire and a power wire.
NARVA truck & trailer lamp
P/No. 85874BL Marker Lamp (clear)
from my understanding (after it happen) these work by earthing or something along those lines...
picture in link - http://autoonecai.cart.net.au/details/528947.html
i guess i wont be calling round to help ya then :( . those lights are just a marker type light. yes they require pos and neg to work. the only thing that i may suggest at this stage is to disconnect the park/headlight switch at the steering column and see if the lights go off. if the don't you know it is definetly in the harness to the rear or possible to the front. if the lights go out then u might have a switch problem. if the lights stay on with the switch disconnected then trace the harness to the rear and disconnect any plug connectors and c if the lights go. it a process of elimination unfortunalty. c how u go with that if it gets to further involved u might have to visit your local auto elect. sorry mate. let us know how ya go.
wired up new (proper) numberplate lights tonight...
with the fuse out (lights off) i tested both wires with a test light. both wires were showing a negative (earth) current through them. im unsure if there is supposed to be an earth current through both wires??? -
- is that normal?
- or could it possibly be causing me the problem?
i put the fuse in (which sends power to the lights) and one had turned into a power which i imagine is normal.
then...
I wired the numberplate lights up... working.
now...
with the fuse still in (which means lights are on) i unplugged the connector plugs behind the tail lights. still stayed on.
i plan to remove the rear seats tomorrow, as i think there is a connector plug behind the seats.
you advised to start from the front and move towards the back. so i will remove steering column surround and start from the switch (indicator stalk).
I imagine the wiring also continues under the drivers side door strip/scuff plate.
Is this correct?
cheers
- is that normal?
then...
now...
Is this correct?
cheers
yeah mate that should be normal. i'll double check on me wifes 33 tomorrow on how they switch. when u say you unplugged the connectors behind the tailights did you disconnect each light and the front lights stayed on or you unplugged the rear lights completely and they stayed on? yeah if you start from the front to the back you should stumble across the problem. just remember to check the front parkers as well, to make sure they go off as well if you start unplugging the harness towards the rear. good luck. icon1.gif
Edited by 116.hks
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
