OK, sell off time.
DR30rsx h/lights:$200
DR30rsx h/plate t/lights: $150
Front struts+brakes: $100
Rad with fans: $100
STD turbo .63: $150
STD ecu+afm: $100
STD coil with cas: $40
Ironmask bonnet: $40
Lots of other engine bay bits as well inc brake master and p/steer pumps line etc just let me know via PM.
Cheers, Vaughan.
https://www.sau.com.au/forums/topic/230000-dr-bits-lights-etc/
Not seeing a PM from u Dan??? Sorry guys I have no pics atm as being the dopey bastard I am I forgot to take some before I flew out, but I'm going to try and convince the Missus to take a few pics of the lights and shit and email them to me, any of the other stuff will have to wait for just under a cupla weeks, apologies for any inconveniance.
Vaughan.
Hmmm maybe dan Pm'd you elsewhere lol.
Any chance you can get either teamdat or another ozdat WA member to send the struts down to melbourne?
Cheers,
Waz.
PS: the struts have a similar rotor bolted behind the hub design as k,200b,1600 etc? Not intergrated like mr30 and aus r31?
Cheers,
Waz.
Hey Dan/Waz, postage on the struts would have to wait untill I get home because they are in a big f-off tool box which is locked and I have the key here at work, plus I have to work out freight cost etc etc.And yeh the rotor set up is the same as the Datto bolted from behind style.
Cheers, Vaughan.
Straight bolt on for what Dodgy??
Tail lights up for sale again as R30kansai has dissappeared off the face of the earth.
Rad sold too.
Ok have also got an DR30RS dash cluster $100 and a set of standard rear struts/springs $50, and tail lights STILL for sale as well.
Vaughan.
Vaughan.
Turbo cluster I take it? If you don't mind, what's the odo reading, and is it an early (clock face) or late (grid pattern) type?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
    • Yes then it will turn on but I want the car features to work
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
