hi.
when i was at school the other week i noticed on a couple of vl turbos that they
moved there afm from the intake pipe ( the one that goes to the turbo )
and put it on the other intake pipe ( the one that goes to the throttle body )
and was wondering if anyone with skylines done it before?
and if u got any pictures
cheers and thanks in advance
https://www.sau.com.au/forums/topic/230118-moving-the-afm/
Hi.
Most general/basic type of things have been covered at one point or another
Here are some of the search results
http://www.skylinesaustralia.com/forums/Af...ter+intercooler
I will lock this thread being it has been a well covered topic with good information
Thanks
https://www.sau.com.au/forums/topic/230118-moving-the-afm/#findComment-4043952
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
