how's the car running now ? .. is the throttle getting any better ? ... im no mechanic but from previouse complaints it sounds like miss fire .... my mates gti-r would backfire and not rev any higher then 4500rpm
he had some cash lying around put a wolf v500 and it told him exhaust leak, some how a hole in the dump pipe was mucking the sensors up and throwing things out.. 11k later its runs like a jet :P sorrry a bit of subject ..... check your spark plugs hehe
https://www.sau.com.au/forums/topic/230424-woooooo/page/2/#findComment-4064463
finally registered in my name :)
Just filled it up with premium. $98 :P will be interesting to see how many k's I get
Looking forward to throwing in the JVC DVD player tomorrow arvo though
Oh and the engine runs smoothe as.. Must have been water in somewhere.
Edited by Silhouette31
https://www.sau.com.au/forums/topic/230424-woooooo/page/2/#findComment-4086279
finally registered in my name :rolleyes:
Just filled it up with premium. $98 :) will be interesting to see how many k's I get
i had something similar ages ago i washed my K&N panal filter and re-oiled it but not all the water had drained out. made it cough and splutter till it was properly dry (stoopid me)
https://www.sau.com.au/forums/topic/230424-woooooo/page/2/#findComment-4087221
aaargh!!
my passenger side fog light was blown, so I took the housing off to change globes..
didn't look at how the clip that holds the globe in works and just took the little screw off for the earth tab.. When I put it back together (and worked out how the clip worked), the head tore off the screw... Now I have nothing to hold the globe in and no earth tab... So my entire fog/indicator light housing is useless cause of one stupid screw!
I've put up a WTB if anyone has one.
http://www.skylinesaustralia.com/forums/Wt...or-t233204.html
https://www.sau.com.au/forums/topic/230424-woooooo/page/2/#findComment-4088422
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
