Hi All,
Got a SAFC2 to put into my Series 1 RS four.
All diagrams and manuals i can find on the web for it are wiring diagrams for the SAFC1 not 2. The 2 has a few extra wires that im not sure to do with.... Does any one have a diagram for the safc2's loom?
Also on the apexi website it says I use the N-6c ecu diagram for the pinouts (From here http://www.apexi-usa.com/pdfWiring/7.pdf) But it doesnt have the knock sensors labeled?
Some quick replys woold be wicked cos I wanna get it in thisarvo!
PS ive searched :)
https://www.sau.com.au/forums/topic/230509-safc2-install/
found this :
Red - power
Green - rpm signal
Gray - Throttle signal (TPS)
Brown - Ground
Black - Ground
Yellow - A/F Output (this goes towards the ECU)
White - A/F Input (goes away from ECU)
Blue - can be used as O2 sensor voltage meter. Hook up to one of the primary O2 leads.
Pink Not used (Used on Karman vehicles)
Orange Not used (Used on Karman vehicles)
Purple - Knock
Looks good. Im not going be hooking up the pink orange or blue correct?
Now all i need is a ECU pinout diagram with the knock sensors on it :)
https://www.sau.com.au/forums/topic/230509-safc2-install/#findComment-4050254
Ok. Looks like Apexi have removed the manuals for the SAFC2 from their site. Some other place has them hosted here: http://www.kaichia.com/media/safc2_wire.pdf
http://www.kaichia.com/media/safc2_user.pdf
Im going to go by the cpu pin out from their. Sound good?
Edited by kidafa
https://www.sau.com.au/forums/topic/230509-safc2-install/#findComment-4050339
yeah, the N6-B diagram.
https://www.sau.com.au/forums/topic/230509-safc2-install/#findComment-4050972
thanks for that QWK32. Thanks the diagram I went with :rolleyes:
Its all installed and it turns on ect. As im yet to get to the dyno (will happen in a week or so) What do I need to do so that it doest adjust the mixtures yet? I have purchased the unit second hand so I have no idea what the current tune/tunes it has on it. Is their away i can completely reset it or something?
Once it is reset will i need to do the car setup eg hot wire ect so that I can drive it? If so some one like to share the love with the settings :)
Cheers,
Chris
https://www.sau.com.au/forums/topic/230509-safc2-install/#findComment-4051146
yeah, if you want to reset the safc you can. or if you think the settings are correct and just want your mixtures to be unaltered you could go into the correction maps and set all the values to zero.
on page 60 of the manual you used from that website, is how to do the initialization (reset) just in etc. and scroll down to initialization.
to just set all the correction maps to zero go into "Setting" and in Hi-Thrtl and Lo-Thrtl set all and values on the map to zero.
if you do the initialization, which is what i would do. the settings you need to set to get the car to run are: go into etc.
Sensor Type ->
Sensor No: HW and 04 in and 04 out
Sensor Calc: 01 in and 01 out
Car Select ->
6 Cyl, and the Thr is the arrow pointing up and to the right.
Dont worry about Dec-Air and on Pg 30 is how to do the Knock Setup. Just so it displays the correct value, not needed to run the car though, you could get the tuner to set this up for you if you want.
Edited by QWK32
https://www.sau.com.au/forums/topic/230509-safc2-install/#findComment-4051327
for the throttle setting the aroww only points to the right up or down not to the left. so im guessing you mean right and up?
Also just wondering why i hvave read different sensor no's for in and out and snsor calc no's on the forums
eg check the basic settings post in this thread :http://www.skylinesaustralia.com/forums/Safc-Install-R32-R33-G-t85232.html&hl=safc+install
https://www.sau.com.au/forums/topic/230509-safc2-install/#findComment-4051342
yeah sorry, up and right (i edited my original post so its correct). the Sensor number is for what kind of airflow meter / Map sensor you have. So, for all skylines/stageas with RB engines running stock AFM's it is 04 04, except for GTR's which is 03 03. if you have a Z32 or Q45 Afm it is different.
eg, for a Z32 you need to set it at HW 02 in and 04 out. 02 is the Z32 afm code, so you are inputing a 02 type afm signal but want an 04 type afm signal for your RB engine ECU.
and the different Sensor Calc numbers are for multiple AFM applications or for running 1 AFM on a multiple AFM ecu. so for non-GTR RB engines it is 1 afm signal in and 1 afm signal out, or 01 01.
Edited by QWK32
https://www.sau.com.au/forums/topic/230509-safc2-install/#findComment-4051356
thanks so much mate. Someone on a internet forum that really knows their shit its good to see once in a while :)
Too true. I've got an SAFC2 coming and I need all the homework. I'll be installing it myself also.
https://www.sau.com.au/forums/topic/230509-safc2-install/#findComment-4051498
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
