Regrettable sale due to another project, had a buyer but no funds. So the ultimate sleeper is for sale.
2005 Holden Statesman fully optioned with grey leather interior.
26000 genuine KLMs with full holden service history and log books.
5.7 ltr GEN 3 with PWR intercooled/aftercooled Supercharger with carbon fibre shaft.
90mm Billet throttle body.
Bigger injectors.
Yella Terra Ultralite shaft mounted roller rockers 1.8 ratio
Pedders suspension.
350mm cross drilled front brakes with braided lines and larger calipers. 330mm cross drilled rear brakes with braided lines and larger calipers.
Full custom made 4 into 1 extractors with full 3" mandrell bend stainless exhaust with hand made high flo cats and mufflers. Made by Darren Difillipo in Melbourne.
Maffless tune (no AFM)
18" x 9" mags with new tyres
Dark tint windows.
all work done to the in January this year, made 380hp at the rear wheels on pump fuel. will make more with a camshaft change. I have receipts for $20 000 just for the parts alone, no dyno time or fitting. I have photos but dont know how to load them on the site. e mail me or call me on 0412950192.
full 12 months QLD rego and will discuss shipping in deal. will refund airfare to buyer. price $39000.
Body is immaculate with not a mark or scratch perfect condition.
Thanks Dave.
Hey mate, to upload pics, hit reply, then go to browse in the bottom right corner of the page. After finding you pics, double click on them then hit upload. It might take a while depending on the size of the files. Hope that helps.
Shaun.
Bigger injectors.
Pedders suspension.
Dark tint windows.
Thanks Dave.
  • 3 months later...
Bigger injectors.
Pedders suspension.
Dark tint windows.
Thanks Dave.
Price drop $36000 this car has not been driven, dont have the time or space in the shed anymore, this is a great car.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
