  • Replies 40
Posted Images
Jason fer sure - he can actually act for a start, has been in MUCH better movies, and gets to drive much better cars.
Oh, and he is a LOT more quotable..
"Quick, before ze germans get here"
*edit - Vin is only sexeh coz he looks like Dan anyway.
Yay Jason's winning! lol Vin = Dan
This is a male dominated forum... You won't get much
I'm hotter :ermm:
I'm sorry ur not apart of the poll :D
Shouldn't really matter should it?? They both crave teh penis.
Well you should vote then, you have something in common with both of them :D
jason statham is the coolest muthaf*kka alive
i'd drink his piss maybe
if he asked
uhh....... ok Kym he's urs...I'd never go that far :thumbsup:
justin timberlake
ans skyryan :ermm:
Pfft...... JT is a pansy....but Ryan.... dammit now I have a third contestant *adds Sky Ryan to poll* :P
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
