Item: Nismo Super Coppermix Twin Plate Clutch
Age: Brand New
Condition: Brand New
Price: $1,600.
To Fit: BNR32 93/2~ BCNR33 Skyline GT-R (pull type) (What car)
Contact: via PM.
Comments:
Brand New Super Coppermix Twin Plate Clutch Kit by the absolute best in Nissan performance, NISMO.
These clutches are equipped with the `damper type` center boss/hub for easy drivability. With the increased diameter of the discs (225mm) and the addition to copper into the facing NISMO has been able to significantly increase the potential of the clutch to 670ps (660hp), durability and driveability over the previous G-Max series.
Highly recommended for daily-use vehicles with weekend spirited driving, drifting or circuit use.
The clutch comes complete with the Release Sleeve Bearing.
Photos coming soon.
guys this is a dirt cheap price.. even cheaper than nengun.. which sells em for 2k i believe and i think average RRP in AUS is $2400.
I use one in my gtr, they're good.
Goodluck with the sale, fantastic price!
I have decided if this doesnt sell at the ridculously low asking price I have set by the end of the month then the price will be adjusted up to $2,000.
It represents great value at the asking price so, for those seriously interested - I suggest you make a move asap.
Gavin.
Taken from Nengun's website:
SUPER COPPERMIX TWIN
A super - strong clutch that combines ease of operation with the ability to handle allowable outputs of more than 600ps - this was the concept behind the development of the SUPER COPPERMIX TWIN. NISMO first used this concept to develop a carbon twin product, a process that took two years, but the low quality of carbon facings meant that they could not provide the performance of COPPERMIX. Over the next year and a half, twin plates using COPPERMIX were delveloped. So the result of three and a half years of development was the SUPER COPPERMIX, the final model of the NISMO multi-plate clutch series.
Allowable torque of 84 kgfm for dynamic friction (Stactic friction:143 kgfm) Handles an estimated allowable power of 670 ps
These numerical values are NISMO standard measurement values measured using a push - type clutch combined with an RB26DETT engine. Evaluations were made based on street and circuit conditions. No quarter - mile evaluation was conducted.
The multi-plate clutch system takes "the ease of use" and "high power handling" forte of COPPERMIX to the next level.
Uses a center hub
Using a center hub increases the amount of engagement between the clutch disc and the transmission`s input shaft, the serrated part to the lower surface pressure on the serrations. This reduces the wearing of the input shaft and prevents disengagement trouble. At the same time, this also reduces the impact shock on the serrations during clutch assembling and suppresses offsetting of the two clutch discs making transmission installation easier than for single clutches.
Light Flywheel
Equipped with a lightweight flywheel manufactured from special chromoly, the ideal weight has been provided to ensure torque.
Uses an aluminum cover and lightweight flywheel as a set
A special aluminum cover with excellent heat radiation is employed. Also, this is combined as a set with a special lightweight chrome-molybdenum flywheel to achieve the ideal weight setting for the attained torque.
Edited by JUN R33
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
