Id be interested to know a ballpark price for the line locker and instructions. Ive looked at one of these, but found that i needed two units because something about the brake lines crossing over as a safety feature. I didnt explain that very well, but maybe you'll know what i mean.
Shaun.
unsure of exactly what you mean. there is no point in the line where the brake line for the rear of the car is single?
if not i may be able to look into a way of bringing the two lines into one close to the master cylinder and then split off again. its that or 2 lockers. haha
^^^^^^+ 1 for above.
Im assuming these aren't legal for a road car? Are there any safety concerns? Im pretty interested though.
Shaun
correct. offroad use only. like most products that mess with brake system - bias adjusters, etc. no safety concerns though. unless you leave it on whilst driving - having no back brakes and thus much worse braking ability.
Keen - details please
what else would you like to know?
Yeah, im keen for those prices.
I'd like some instructions on how to do it though.
Shaun.
i will supply instructions with the kit. but it is fairly straight forward, you can even get your local brake place to install them.
i now have them in stock ready to go
Yeah, i find it difficult to explain, but i just know that i had a look at a line lock kit previously, and found that i needed two kits in order to make it work. Im not saying that im 100% correct, but i wouldnt mind confirmation that you definately only need one and where the kit is best installed. Also, do the hard lines have to be flared? As soon as i know these things, ill transfer the money!
Can anyone shed some light?
Thanks,
Shaun.
Do you have any pics of the kit?
Interested in knowing what / how to fit it all up as well.
Cheers champ.
no pics currently but will have another camera on Monday.
basic rundown of installation is this.
1. using pipe cuter - cut rear brake line appropriate to the line locker.
2. put brass fittings on each end of brake line
3. using a double flare tool - flare both ends of the brake line
4. screw brass adaptors into line locker
5. screw the brake lines into the brass adaptors.
6. tighten up all fittings and tek-screw or similar solenoid to body.
7. bleed brakes and check for any leaks, etc once pedal feel is 'normal'
8. run 1 wire to earth and run the other one to a switch and then to +12v
Yeah, i find it difficult to explain, but i just know that i had a look at a line lock kit previously, and found that i needed two kits in order to make it work. Im not saying that im 100% correct, but i wouldn't mind confirmation that you definately only need one and where the kit is best installed. Also, do the hard lines have to be flared? As soon as i know these things, ill transfer the money!
Thanks,
Shaun.
yes, the two brake lines have to be flared. pm sent RE: 2 kits or a crossover system.
I just got under my car and there is only one line going from the brake booster to the rear. It then splits to each rear wheel via a distribution block, so i suppose you'd just install it in the single line before the distribution block. Its a very small diameter line though, so it would be pretty difficult to flare, but certainly possible. Ill include a pic of the distribution block. Note the single line going into the block, then the two other lines going to each rear wheel.
Shaun.
Edited by Shaun
Shaun.
i should of asked what model car you had and could of answed it. (a 32 i take it) lol
it will plumb in fine.
pm sent.
  • 1 month later...
i've got one of these sitting in my draw, plus a switch and all wiring, instructions etc. as new, never used. in brisbane if anyone wants one will sell for $80 as it's just sitting there.
0427282562 if you want it!
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
