My bunky, Ford Meteor, has to last me until the banks get their act together and finance me! In the mean time I want to get a few things ixed on the bunky. The main thing I'm stuck with is, my driver's side window is broken (the lever that holds the glass in place) who would I contact to fix it? I knwo this sounds like a stupid question but I've asked several people, and no one knows!!
https://www.sau.com.au/forums/topic/231729-window-fixing/
Just call around some wreckers, I reckon you could get a whole working door for $50-$100... paint probably won't be the same, but its quick and easy & cheap :wave:
but then it won't be the gherkin Tris?
it'll be like....the Gherkin with the tomato door :(
https://www.sau.com.au/forums/topic/231729-window-fixing/#findComment-4072409
k so this probably wont help that much but most of the time with wonders like the gerkin best bet is a little diy action and a visits to your local wreckers
ive fixed afew window winders (mostly on mates comos) and most of the time a little elbow grease can fix it
https://www.sau.com.au/forums/topic/231729-window-fixing/#findComment-4075236
whats actually wrong with it? the lever is missing? or it doesnt wind up and down?
If the levers missing just get one from a wrecker easy as.
If it wont wind up and down then get the window mech from the wreckers.
Take off the door trim theres like 3 bolts? or so that hold it in place with the glass in a channel, take the mek out replace it with the new one, reseat the glass, done.
Its really not a difficult process, if you can get someone on here to help you out, better half of 2 hours.
https://www.sau.com.au/forums/topic/231729-window-fixing/#findComment-4076185
Spark plug in the fuel tank??
Take it to a mechanic, we do shit like that more often then you'd think. Us mechanics are pretty useful!!
SPark plug? wtf? lol I'm talking about the window!!!
Yea... its not hard. You're like playing with cars. DIY Mel :(
If not... I have a sledge hammer you can borrow :D
yes plskthanks
https://www.sau.com.au/forums/topic/231729-window-fixing/#findComment-4076492
all you need is someone with a little bit of mechanical knowledge to fix the window regulator. Its not exactly brain surgery. I pretty sure anyone could do it. :D
umm no the lever is snapped not stuck
1. the lever is snapped
2. we masde it so it can't wind up and down so that teh glass doesn't smash
3. obviously I've taken off the door trim, how else would I know the lever has snapped??
Ok so you guys reckon go to the wreckers and get a new regulator yeah??
https://www.sau.com.au/forums/topic/231729-window-fixing/#findComment-4077905
No longer need help with this! Thanks everyone for your ideas I got some really good quotes from RAC Auto Service Centre's if anyone has the same problems and you don't have to be a member.
Btw in the crash, the pen still held the window in place!! :P *Props to Bushman Mechanics*
https://www.sau.com.au/forums/topic/231729-window-fixing/#findComment-4094889
On this window topic... Does anyone know of a place that buffs scratches out of windows? places like O'Brian etc don't do it anymore because it thins the glass and affects the structure of the car.. but i just want the driver's and passenger's door windows done.
https://www.sau.com.au/forums/topic/231729-window-fixing/#findComment-4095109
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
