Hi guys
Im sure this has already been discussed a million times but I am new to all of this ;)
I have just bought a 03 V35, its currently on its way over to Perth, have only seen photos so getting a bit amped!
It has the standard bose stereo and pop-up montor.
I have seen some with the dvd drive i the glove box converted to a regular dvd player, is this as simple as removing the old one and putting in a in car dvd player.... surely not.
Also, if I decide to keep the gps dvd reader in the car, is it possiabe to convert it all to English (Australian!) and get the maps for Australia???!
If there are any links to prvious posts where this has been discussed could someone post a link. Dont want to go over what people have said before!
Cheers guys
https://www.sau.com.au/forums/topic/232080-v35-tv-screen/
I have just done some reading though this excelent forum.
So I know that I can turn it into a GPS working in Australia
One of the cars I looked at here in Perth had a different head unit in the glovebox.
Is it as simple as putting an Aussie DVD player in there and hitting the TV button on the display to get an image.....
I suppose audio is another issue...!
https://www.sau.com.au/forums/topic/232080-v35-tv-screen/#findComment-4073609
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
