Hi All,
I'm just wondering what problems there may/would be installing an R32 turbo on an R33. I know lots of people put R33 turbo's on R32's and have read something about a restrictor in the oil feed line of R32's so that there is a different oil pressure due to different bearings being used between the turbo's. Can anyone confirm this? Just wondering if anything special needs to be done swapping them the other way around.
Ur prob thinking why would I wanna put an R32 turbo on an R33? Well the turbo on my R33 blew and the only 2nd hand turbo I can find for it is expensive, so for that price I would rather just buy an aftermarket one. Only problem is the person that looked at my car also believes that the engine is damaged, so I don't want to buy an aftermarket one for which I will need to get car tuned on dyno if I'm not certain the engine is ok. But, I want to put a turbo back on the car to confirm whether or not there is a problem with the engine once the turbo issue is resolved.
So, I was thinking maybe an r32 turbo might be a cheap temporary option for me to check how the engine goes with the turbo issue resolved. From what I've read it seems an R32 and R33 turbo is a direct bolt-on swap, is this the case?
Cheers
https://www.sau.com.au/forums/topic/232122-r32-turbo-on-r33/
R33 turbos aren't expensive, certainly not anywhere near the realm of an aftermarket turbo. And even after you find a problem (if there is one) with the engine, you are still going to have to remove the R32 turbo and replace it with something larger.
If anything, the R32 turbo could damage your engine as being undersized it will be running alot less efficiently which equals higher inlet temperatures. Also, since the turbo will be running higher speeds to keep up with the 25 you risk having the turbine on the RB20 turbo failing.
RB25 turbo with manifold, dump and lines went for $150 on SD.com forums today. Saw one going on this forum last week for $200. Found one (again this forum) rebuilt for $500.
If you are getting aftermarket turbos for this price then they must be cheap copies
Edited by daisu
Rb25 turbos come up for sale almost weekly - and priced @ $400
Not expensive at all when aftermarkets are $1700+
not sure what price you'v been given for an RB25 turbo, but $400 is the limit.
The RB20 turbo is too small, and could cause issues with the tune/ECU and so on being it'll be on boost earlier than normal
I actually live in NZ. The only R33 turbo I've been able to find so far is $700 from a 2nd hand parts place which is ridiculous, but there's lots of R32 ones around.
Guess I will just leave it until I can find a cheaper one since I still have my R32 to drive around in. Hopefully I can find one soon.
Cheers for comments
sorta on topic but does anyone know if rb20/25 exh manifolds are different at all?
reason i ask is the to4e turbo i have is supposed to bolt up to my stock mani & if the rb25 is different in any way it might be good to know.
thanks
Cheers for comments
So just purchase one off the forums here? Living in NZ shouldnt pose one problem.
Have the seller ship it over.
Wouldnt be more than $50 postage at the worst.
Thats what, $250 cheaper to begin with.
Answering the question, yes you can and yes it will work, it will spool early and run out of puff quickly. If you put the stock r33 actuator on it (so its only running 5-7psi) it should cope ok, They don't like pushing more than ~ 150rwkw worth of air, so run the lowest boost you can, and it will get you by (i wouldn't go bouncing off the limiter though)
That said, your better option would be to get another rb25 turbo, a vg30 turbo or similar T3 (an old vl turbo even), you can get them in aus for around $300
Rather than start a new thread................ might as well hijack :dry:
Just wondering if the r33s1 and the r34gt dump pipes are the same??
I know that the r33s1 and r33s2 turbo's have slight differences but that has nothing to do with the dump.
Hopeing 34's will be the same????
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
