  • Replies 373
Posted Images
Well started doing it the drive home after I picked it up... Few times when I stopped at lights it'd just cut out so I'd have to restart it. Doesn't do it every time but idles a bit funny too like it's threatening to do it. Did it 4 times yesterday when I drove home :(
Also when I was driving to a friend's place I started losing boost/power and could hear a hissing noise... At the friend's place, I checked under the bonnet to see if I could work out wtf was going on. Found that a clamp was loose on the big air intake pipe on the right hand side (the one with twin turbo written on it) and the rubber hosey part coming off it was slipped down. Fixed that and tightened it and seemed to fix the probs breifly but happened again when driving home.
Checked the same spot and this time it looked fine... Getting it all checked by Autotech tomorrow to be safe and I haven't really driven it much since cause it's pretty embarrassing!!! Looks like I'm stalling all the time :(
I should add that I know it's quite possible that I have more than one problem here. Could be any number of things as to why its cutting out.
Air hissing and already 1 loose hose found likely to be caused by the person playing around in that area on Friday.
hi gtrkat, i have been following you're progress so far and u have all the goods motor wise. and with any build the headaches and dramas arrise when everything is put together and you're driving it for the first time.
from you're last post with the looose hose/pipe/clamp ' air-hissing' noise and it stalling, i'm sure u'd have to change you're spark plugs as they would be fouled by now, so factor that in when you go to talk to the electrician, and get him to re-emburse you for them.
just my 2 cents. good luck with the car, and hope to see it on the road soon, problem free :D
Hey Matey cheers for that. It was only driven a tiny amount before getting fixed. I'll get onto the guys at Autotech and get them to check it but it doesn't feel like they've been affected by this at all - I can tell you he will be paying for them if there's an issue though considering they're brand new!
Not yet but Greg is going to snap some for me before it goes :D
Autotech are also going to take some of it all fully assembled before it gets dropped back in.
I was just reading through and noticed there were no pics of the head so I attached some below. Someone asked what the weight differences of the pistons were, lightest was 366.9, heaviest 368.3, the pins were within .1g. Matching them up with the lightest piston on the heaviest rod small end I had to remove a max of .7 grams from some rods. The crank was balanced as well. The crank balance from Tomei is very good but you can get it a touch better. The kit fitted with no mods to the block or pistons. Overall the 2.8 is a really nice kit.
Kat, I saw the dyno graph from the initial tune the other day, very nice torque curve! Will be nice to see once everything is sorted completely.
Some pics of the head:
Cheers,
Greg.
how is yours going now Steve-O? what kind of response are the GT-RS's giving with the 30?
Mate its on the run in tune (got 400 more k's to go, ill do them quite fast) then swap ECU's and go for some decent boost. Its just the best combo on the big bottom end, wish i did it sooner and didnt waste time with the 2.6 block :D
Basically its got the response of the poxy little stock twins but way, WAY more torque and once the boost is there the power aswel.
Hey Greg cheers for that! I'm so happy with the car, words can't even describe!! Torque curve is great, its just such a different car now! (Should add that more pics are on facebook and my photobucket of the whole process)
Run in tune is done but still not doing anything terribly nasty to her just yet. Few things need to go still, in the not too distant future I'll be getting a metal cat and choosing another exhaust as mine both aren't up to scratch anymore. Will also have a new front mount but not sure when... Kinda letting our finances settle after such a large amount of work and Christmas all at once!
Much nicer to use setup than when you had the GT47 on there then?
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
