  • Replies 188
its a downgrade in model, theres no denying that. So for you 33 haters, SHHHHHHHHHHHHHHHHHHHH
+1 for 33 haters... some people prefer the OLDER shape... so what! Is it newer? no. did it come out after the R33 shape? no. is it an upgrade? no. there ARE those of us that prefer the R33 shape out there peoples!
..............Am I in a Skyline enthusiast forum or an "I hate R33's" forum? :(
i dont understand your reasoning kahli,you said it just gets damaged too much at school by jelous people,yet you have bought another skyline....and running costs,lol minimal difference if any between them.
is it just me or does this not make sence to anyone else ether? good on you for buying another one tho but i just dont understand the reasoning behind it.
I'd just say, an opinionated skyline enthusiast forum!
I like all Skylines (even the R30!) but I preffer the 32/34 shape... and so did Nissan! :P jk jk
Stagea's are heaps cheap now, like 10k for a series 1 rb25det auto awd.
awesome upgrade from a 33-32-s15.
I'll too have a pod to go to a new home next week, a K&N pod filter for a RB25det either stock or z32 afm
lol yes very openly opinionated
I definitely wouldnt mind removing my K&N pod too - less psh psh but the intercooler pipe is in the way of the snorkel for the stock air box dang it :(
no, a downgrade would be going the turbo model down to a NA model.
this is a change in year of car so the term "downgrade" is invalid, especially when your moving to a lighter better performing car :(
You tell em Vu.
Damn 33 haters.
Incorrect, if i went from a 32 to a 33, you'd say "nice upgrade". She has downgraded in years, theres no argument about it.
lol i would say "ahhhh why would you do such a thing!??"
downgraded in years yes, but you didnt say that at the start :(
lol u guys are trippers.
gernerally 33's are better.. and not because of age, they got better brakes, suspension, larger engine (i wouldnt say better than RB20, but if u like less revs and more torque), upgraded interior, generally newer and longer lasting parts. only thing the 33 has going against it is the looks, looks very out dated.
anywho after all of that, i would still go a 32 :blink:
oh.. and just coz a car is newer doesnt make it better. thought some of u guys were smarter than that lol. i mean why get a 32 gtr.. get a vx commo, its newer and must be better right :P
Edited by steveP
LOL at steve :blink:
And +1 Jack...it doesn't make sense. If it was me i guess i'd just keep it till i could get the S15 right? And anyways. People at school are just jealous and they always will be whether its a 33, 32 or an S15. Just cos all they can afford is a commonwhore :P
i have a hks mushroom pod and with a few more psi than standard i feel it's pulling more air in than the apexi i had on! getting a flutter can also be done with an aftermarket bov, just tighten the spring a bit and you get the flutter at the same time a bit of air escaping! but even now i'm running the standard plumb back on my intercooler pipe because quite frankly it's been better than any bov's i've put on!
how come so much hatred for 33's? yes it's a whale but it still managed to lap the nurbuurgring 20 seconds faster than a r32! :blink:
ohh god
this arguement is going nowhere
it comes to personal preference
going from 32 to a 33 is an upgrade
going from 33 to a 32 is a downgrade
simple as that
Here we go!
:blink:
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
