Hey guys, got a series one dash center peice that runs from the stereo surround upto the cluster, includes all buttons, clock, and comes with turbo timer inbuilt with about 8cm of wiring out the back of it.
Asking $20 pickup on Gold Coast
OR $20 + post
PM if you want it!
https://www.sau.com.au/forums/topic/232790-r33-dash-center-peice-20/
  • 1 month later...
  • 10 months later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
