Fs: R34gtt Factory Smic, Nismo Intercooler Air Duct, Factory Piping, Nismo Blank Key, 350z Rays Wheels
Hi guys,
Clearing out the garage, have the following items all in good condition:
1. Factory R34 GTT SMIC - $150 firm. Good upgrade for 32,33 and Stageas.
2. Nismo Intercooler Duct - $100ono. Discontinued from Nengun was selling for $210 http://www.nengun.com/nismo/intercooler-air-duct
3. Factory R34GTT intercooler piping including factory BOV - $50
4. R34 GTT Nismo Blank Key RN010. Brand new uncut will also fit S15 with no factory immobiliser. 3 available $100 each.
5. Rare 350z Rays Engineering wheels. 18x8 +30; 18x8.5 +33 5x 114.3 Immaculate condition and forged. Similar weight to TE37s and look good on most Nissans. Suit 32,33,34,S15,S14, 180sx etc..$1400 pickup
Items available to be picked up Brisbane Southside.
Thanks.
Whats the benefits of the NISMO duct over the standard duct? Looks huge compared to the stocko so does it scoop a larger amount of air and direct it or?
Edited by Granthem
Quote from Nengun website:
Allow more airflow to the Intercooler with the Nismo Air Duct
So I guess yeah...more airflow compared to stocko. Never fitted it but it came of an R34 GTT.
Will the R34 intercooler bolt up to the R33 without any fuss or will i need different piping/mounting to make it fit?
Not 100% sure on tht but I have known R33 and Stagea owners in particular use R34 SMICs as factory replacements with good results. There is a thread somewhere for a stagea...I'll see if I can find info on the R33
EDIT/
Beauty of the search button. Here is a fine example for you. Judging from the pics of both side by side, I would say install would be very straightforward.
http://www.skylinesaustralia.com/forums/R3...amp;hl=R34+smic
Edited by n15m0
will those keys opent he door and start ec the r34, for some reason i thought they had chips in em or something?
if not ill take a key :D
Hi, I'm interested in the intercooler.
Would you sell the intercooler+shroud for $150 pickup?
I'm trying to decide between that and a second hand front mount kit :)
if not ill take a key :)
The keys do not have built in immobiliser chips. I have one myself for the 34 and all you do is go to a key cutting place to get it cut from your original.
Looks like this:
let me know as this may be the last one I have.
Thanks.
PM Sent.
Update:
2 x Nismo Keys SOLD
1 x Nismo Key left - Bryn if you're interested let me know via PM. Thanks.
Everything else still for sale!
Rays Wheels back up for sale!
Tosser paid me a deposit and kept on stalling, now he's changed his mind....so I'm keeping the deposit until the wheels are sold.
$1300 pickup no more no less!
SMIC, Intercooler duct and 1 x Nismo key still available!
I believe the intercooler duct is used for Nismo S tune front bars. After some research :P
Good pick up Grant..I believe you might be right.
Wheels still for sale $1200 pick up firm!
SMIC still for sale
SMIC Sold!
Rays Wheels - $1200 pick up!
Nismo Intercooler duct - make an offer!
Nismo Key - Withdrawn.
IC piping and BOV still for sale
  • 2 months later...
  • 3 months later...
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
