Originally posted by Steve
Emissions test are a bloody joke anyway.  If a car is not passing an emissions test, one of the ways to fix the problem is to inject air into the cat - holden have been doing it for years, pretty sure nissan did it too on SR20s.
Are you sure it's air and not methane gas from the driver's seat :)
Found out some interesting news about emissions testing. Aparrently this place that does the $350 test isnt being accepted by regency, but they are still trying to fight that one.
BUT, they will accept emissions tests done by NSW govt, or at mitsubishi. Who cares? I have been told that it is free in NSW vs $3k at mitsubishi, just got to book your car in???? Would be interesting to see how hard it would be to get in, cos if it costs $3k here, NSW suddenly looks like a fantastic place to take a holiday.
Will have to investigate further....
There is a guy in adelaide who can do an emissions test on a dyno, but the accuracy is not high enough for the RTA. To get the accuracy they require involves mitsubishi and $3k.
I was also told that the NSW govt provides free emissions testing, that is accepted in SA. Wonder how hard it would be to get that done? Even if you have to grease the wheels a bit, it would be alot cheaper than going to mitsubishi.
Found out some info on emissions testing
http://www.rta.nsw.gov.au/environment/airq...lemissions.html
There is a free call number to book the vehicle in, and it meets australian standards, free test and takes up to 1/2 hour.
I checked with the guys from regency, and they will pass a car with a larger EDIT turbo if it has an emissions report - probably why you are in your situation 9krpm?
I think I will have to check to see if they accept NSW engineering reports too:)
do you need an engineers report for the mods + an emission test? or just the emission test?
can you recommend an engineer? A friend of mine recommended 'BC Tonkin & Associates'... apparently they are on the Transport SA list of recommended engineers. D. Potts (australian Technology PTY LTD) is on the list as well... is he dodgy or is it just the emission test he does is that is unacceptible?
I've been told all I need is an emission test.
Then I was told to get an engineering report after the emsission test and bring the car for Regency to check. This is like another $70 down the drain after
-?$3K for emssion check
-??$$$ for engineering report
Why does Regency need an engineering report? Couldn't they check/assess the safety them self? If they can't then why do they need to check the car after an expert made a report/safety check aldready?
Toooooooo many loop hole for the government to make money!!!!! STOP IT I DON'T LIKE IT :(
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
