Make:Nissan
Model: Cefiro
Milage: 185,000k's on car, 90,000 on engine
Transmission: Manual
Colour: White with blue pearl
Complied? Yes
RWC supplied? At the right price.
Currently registered? Yes
Price: 16000 or swaps
Contact: Josh 0488707704
Comments / Modifications:
Rb25 (fresh Conversion)
Power Fc and hand controller
GCG 550hp High Flow turbo
HKS SSQV BOV
Aluminium Radiator
Splitfire Coilpacks
New tappet cover gaskets
Front mount
Cometic head gasket
Nismo low temp thermostat
Apexi Pod
Walbro Fuel Pump
Full custom 3 inch straight through to a 5 inch tip
MIG locker.. :rofl:
HKS Hyper D Coilovers
18" Koya GTR4 Mags
T20 Limo Spec Tint
Machined front rotors, new brake pads all round
Immaculate interior
BES Turbo Timer
Nardi Torino Type B Steering Wheel
Drift Button
New Front Windscreen
New Headlights
Rego till July next year
JVC 7inch DVD Player
Polk Audio 6 inch Splits up front
JVC 6 inch 2 ways down back
Kicker Sub in box
MTX Amp
Extra stuff not on the car.
19 Row oil cooler
Tomei Cam Gears
Adjustable Tie Rod Ends
Rear Strut Brace
5 stud hubs
555cc Injectors
Probably forgotten a few things but if i remember them i will post back up.
Images: Yes
Bad one of the engine bay, will get better one soon.
And NO he didnt hit it.. lol
Cheers
Josh
Edited by collins
https://www.sau.com.au/forums/topic/233375-1990-nissan-cefiro/
  • 3 months later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
