GTS20X, I have a Jackson Racing s/c, pretty much the same ones they use in SLK230's. ATM, it's running about 145-150rwkw without any aftermarket ecu. But I'm looking to get something like an APEXi SAFC II to control air and fuel. She's running a bit rich.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
