would recommend Autoworx or Xspeed, people who do this quite alot
or how good are you with your hands? If you've got all the bits you could do it yourself.
Did mine myself, not too shabby, a few f*ck ups but thats how we learn, haha
https://www.sau.com.au/forums/topic/233780-fmic/#findComment-4097991
Yea... do it yourself and save heaps of money. Just take your time with it and be sure you got it all right. You have to cut one hole in the chasis for the piping to go through and might need to take a tiny bit out of the bumper, but hopefully not.
https://www.sau.com.au/forums/topic/233780-fmic/#findComment-4097997
series 2 + greddy fmic... he will have to cut a hole and trim the bumper.
I say do it ur self... i did mine my self as well. But i installed a stealth FMIC, so no cutting required.
However, most work shops like xspeed, c red, tenagah can do it for u for few hundred.
Edited by br3ndan
https://www.sau.com.au/forums/topic/233780-fmic/#findComment-4098007
Just to add, it did cost me a carton.
The intercooler I have was too thick for the metal support behind the bumper so I marked it out and took it a panel beater, he cut it perfectly and sprayed it for a carton of TED's. (tryed cutting it myself but it was too much for the little ozito anglegrinder lol).
https://www.sau.com.au/forums/topic/233780-fmic/#findComment-4099854
cheers guys for the help.. i managed to fit the intercooler my self... i have a problem but.. when i drive hitting around 2.5-3000 rmp the car chokes like ur bunny hopping and spits like (backfiring).
ive only done the intercooler.. havent got no boost controller or gauge. also i heard something about spark plugs..
any ideas?
https://www.sau.com.au/forums/topic/233780-fmic/#findComment-4102859
any ideas?
plugs or coil packs
most probably coil packs . gap your plugs down to .8 or lower but it will probably only help temporarily . then buy some splitfires
https://www.sau.com.au/forums/topic/233780-fmic/#findComment-4103221
gapped the plugs to .8.. went for a drive down the street and struggled to get back into the garage.. heaps of jerking and feeling like the car gonna stall..
damn intercooler.. grrrr
Wogan where abouts is the Cas?
Dukes.. ive got a stock BOV
btw mods = Xforce exhaust system and pod filter...
https://www.sau.com.au/forums/topic/233780-fmic/#findComment-4105596
it's a bit of a long shot, but check that when you fitted your return pipe you didn't knock the plug in your CAS .. i had a problem with a loose wire in mine once and it caused the same issue.
Checked the Cas plug.. feels firms and secure.. its the round thing in front of the engine where now the intercooler runs on top of it hey
https://www.sau.com.au/forums/topic/233780-fmic/#findComment-4105618
U sure theres no leak with ur intercooler piping??
Everything sealed up?
Yeah found the problem br3ndan cheers buddy. i checked the intercooler piping like u said and i found that the hose connection that connects the pipe to the intercooler under the headlight wasnt covering fully and probably was leaking from there.
i feel like a fool now :P
https://www.sau.com.au/forums/topic/233780-fmic/#findComment-4107768
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
